Hi.
In my API tests, while not using a browser, which asks authentication, I am trying to authenticate directly on my code. I am sending the follow POST request:
POST https://10.0.0.1/mgmt/shared/authn/login
"username": "admin",
"password": "myStrongPasswd",
"loginProviderName": "tmos"
I receive the token in the response, as follow:
"token": {
"token": "MY_26_LENGTH_TOKEN",
"name": "MY_26_LENGTH_TOKEN",
"userName": "admin",
"authProviderName": "tmos",
I can’t see any errors in the response, so everything looks fine. After that, I try to send new requests using the token, as follow:
GET https://10.0.0.1/mgmt/tm/asm/signature-sets
"X-F5-Auth-Token": "MY_26_LENGTH_TOKEN"
But I receive as the response a message saying that I am not authenticated.
Authentication required!
This server could not verify that you are authorized to access
the URL "/mgmt/tm/asm/signature-sets".
You either supplied the wrong credentials (e.g., bad password), or your
browser doesn't understand how to supply the credentials required.
What I am doing wrong in this case?
