Im trying to setup an irule that will convert “\” into “/” and also remove redundant “/” (turning “//” into “/”) for HTTP::uri.
What is the recommended way (performance wise) to do these two things in v10 and v11 nowadays?
I also wonder how I can efficiently search for a group of specific hexvalues?
I understand one can use:
if { [string match {*abc*} $uri] }
to search for “abc” withing a string but im not sure that the following will work:
if { [string match {\x00 || \x01} $uri }
or am I supposed to to make a large if-statement out of this or can datagroup list be used aswell?
nitass
2
in case not using data group.
e.g.
[root@ve1023:Active] config b rule myrule list
rule myrule {
set uri [HTTP::uri]
set cvt_back_slash [string map {\\ /} $uri]
set rm_double_slash [string map {// /} $cvt_back_slash]
log local0. "$uri -> $rm_double_slash"
[root@ve1023:Active] config cat /var/log/ltm
Feb 17 03:30:43 local/tmm info tmm[4822]: Rule myrule : /test1\/test2/test3//test4 -> /test1/test2/test3/test4
nitass
3
data group.
e.g.
[root@ve1023:Active] config b class convert_list list
class convert_list {
rule myrule {
set uri [HTTP::uri]
foreach item [class get convert_list] {
set uri [string map $item $uri]
log local0. "[HTTP::uri] -> $uri"
Feb 17 03:55:35 local/tmm info tmm[4822]: Rule myrule : /test1\/test2/test3//test4 -> /test1/test2/test3/test4
Thanks!
Are there any drawbacks of using data group similar to use global variable vs local variable?
