I want to remove specific key=value pair from the querystring if present
-If my uri is /myuri?mykey=myvalue or /myuri?otherkey=othervalue&mykey=myvalue -I want to rewrite the uri such that I remove the mykey=myvalue from the uri in the HTTP_REQUEST event -such that the url is /myuri or /myuri?otherkey=othervalue
Please advise.
Thanks Rajesh
Just one approach;-
if {[URI::query [HTTP::uri]] contains "mykey="} {
set newq ""
foreach param [split [URI::query [HTTP::uri]] "&"] {
if {!($param starts_with "mykey=")} {
Build up new query parameter string
append newq $param
Add new query portion to path
HTTP::uri "[HTTP::path]$newq"
Thank you IheartF5! This did the job.
I actually made a little mistake - I forgot to add in the ? if there is still a query string remaining it should say
if {$newq ne ""} {
HTTP::uri "[HTTP::path]?$newq"
HTTP::uri [HTTP::path]
Thank you again IheartF5!
For everyone benefit, here I wanted to share the final version. From the above script we failed to put & in between each key=value pairs. Here is the working script:
when HTTP_REQUEST { set newq “”
foreach param [split [URI::query [HTTP::uri]] “&”] { if {!($param contains “mykey=” )} { if {$newq eq “”} { append newq $param } else { append newq “&$param” } } } Add new query portion to path if {$newq ne “”} { HTTP::uri “[HTTP::path]?$newq” } else { HTTP::uri [HTTP::path] } }
you may also try HTTP::query. HTTP::query writing data is introduced in 11.5.0.
ID385615 - RFE: Make HTTP::query iRule command support writing data
e.g.
config
[root@ve11a:Active:In Sync] config tmsh list ltm rule qux
ltm rule qux {
when RULE_INIT {
set static::qry_name "mykey"
set static::qry_value "myvalue"
log local0. "origin=[HTTP::uri]"
set tmp [string map [list $static::qry_name=[URI::query [HTTP::uri] $static::qry_name] ""] [HTTP::query]]
set tmp [string map {&& &} $tmp]
set tmp [string trimleft $tmp &]
HTTP::query $tmp
HTTP::uri [string trimright [HTTP::uri] ?&]
log local0. "new=[HTTP::uri]"
test
[root@ve11a:Active:In Sync] config tail -f /var/log/ltm
Jun 8 11:09:21 ve11a info tmm[9801]: Rule /Common/qux : origin=/myuri
Jun 8 11:09:21 ve11a info tmm[9801]: Rule /Common/qux : new=/myuri
Jun 8 11:09:38 ve11a info tmm1[9801]: Rule /Common/qux : origin=/myuri?mykey=myvalue
Jun 8 11:09:38 ve11a info tmm1[9801]: Rule /Common/qux : new=/myuri
Jun 8 11:09:44 ve11a info tmm[9801]: Rule /Common/qux : origin=/myuri?mykey=myvalue&otherkey=othervalue
Jun 8 11:09:44 ve11a info tmm[9801]: Rule /Common/qux : new=/myuri?otherkey=othervalue
Jun 8 11:09:54 ve11a info tmm1[9801]: Rule /Common/qux : origin=/myuri?otherkey=othervalue&mykey=myvalue
Jun 8 11:09:54 ve11a info tmm1[9801]: Rule /Common/qux : new=/myuri?otherkey=othervalue
Jun 8 11:10:03 ve11a info tmm[9801]: Rule /Common/qux : origin=/myuri?otherkey=othervalue&mykey=myvalue&anotherkey=anothervalue
Jun 8 11:10:03 ve11a info tmm[9801]: Rule /Common/qux : new=/myuri?otherkey=othervalue&anotherkey=anothervalue
