I need to send ASM event log into syslog server. I already make event log profiles for ASM (Security > Event Logs > Logging Profiles), and associate it to virtual server. But the syslog server didn’t receive any log from ASM.
My question is:
Is there any more configuration or any pre-requisite configuration that I need to do other than only making event log profiles and associate this profile into VS?
If we want to send log into syslog server, what IP did we use? Management IP or self-IP?
The syslog configuration typically takes management IP address if you havent mention any other address in the source IP details in the remote syslog server configuration.
Also please make sure that you have enabled appropriate logging level for the ASM ( System ›› Logs ›› Configuration ›› Options)
I already done with the “Setting up remote logging” and “Associating a logging profile with a security policy”, but it still not working. I’ll ask the allienvault engineer to recheck their configuration.
Yes the problem is there is no syslog traffic from F5 to the syslog server when we do tcpdump. If we do ping test, the tcpdump show traffic from and to the syslog server.
Any other idea? I have follow all remote syslog configuration for ASM.
and a screenshot of your security tab at the virtual server.
this might also be your issue, in principle the selfIP is used if you don’t create a specific management route. on which interface were you doing the packet capture?
This is my logging profile and security tab of my VS.
I’m not doing any additional routing config on F5, but it’s only my management IP which can ping to the syslog server. I’m doing packet capture on my management IP.
I'm not doing any additional routing config on F5, but it's only my management IP which can ping to the syslog server. I'm doing packet capture on my management IP.
well that is an issue when the actual traffic is coming from the selfIP. can you confirm that is the case by trying a packet capture on the outgoing VLAN interface?
if you want this to work via the management interface you can look into management routes, see this sol:
Create a logging profile, select Application Security
Select Remote Storage in the configuration section
Select protocol UDP (if you are using Syslog) and Add Syslog server Ip address and port number (default port number is 514)
Storage format select appropriate or All
Select request type according to the requirement.
Finish.
That’s it. You will start getting the syslog for ASM module. It is not mandatory to have it enabled in the settings page. You can remove that remote logging configuration in the settings page , if you don’t need the ltm audit logs.
It’s already solve. Your’re right Boneyard, I still need to add a management route so my ASM will send their log into syslog server. Previously I think that the default interface that was used to send log into syslog server was management interface, but actually it was wrong.
The default interface is still the self-IP. It means that the first priority of routing table that was used for accessing the remote server is TMM routing table. Because I have a default route on my TMM, and this default route has no routing into the syslog server, so my ASM will not send the log into the syslog server. What I do then is adding one specific routing with destination to syslog server on the BIG-IP managemet routing table, and perfect, ASM start to send the log into the syslog server.
