Redirection http to https
Hello, Need helps
So, I want to redirect my host http to https.
To do , I tried the different soltions propoesed by F5 such as :
the irule :
if { ([HTTP::host] equals “abc.com”) } {
if {[HTTP::has_responded]}{return}
log local0. “[HTTP::host] [HTTP::uri]”
HTTP::respond 301 Location “https://[HTTP::host][HTTP::uri]”
regsub -all {:\d*$} [HTTP::host] “” host
HTTP::redirect https://$host[HTTP::uri]
return
and:
{  HTTP::respond 301 Location “https://[HTTP::host][HTTP::uri]”}
and
{  HTTP::redirect “https://[HTTP::host][HTTP::uri]”}
I also tested the policy LTM.
in both test, I got the same probleme : so the redirection don’t work in some browser : for few minutes i get an error conexion reset.
if one of you has ever had to deal with this , please tell me what to do !
best regards,
Don’t see issue on iRule. I suspecting issue on something else.
Did your application works with https?
  • Try to validate via https://abc.com on browser
  • Validate the connectivity from F5 device via curl command
  • I would encourage to use F5 provided redirection irule "_sys_https_redirect" rather then fancy.
Hope it will help to isolate the issue.
