Redirect HTTP and HTTPS traffic to the same node in different pools
I have two pools with the same servers but with other ports. I need, that a client, which is connected with http ends on the same server, if it change to https. An I would use cookie-persistence and not ip-persistence. How can I do that?
pool my-http {
   lb method predictive
   members
      serverA:http
      serverB:http
      serverC:http
pool my-https {
   members
      serverA:81
      serverB:81
      serverC:81
virtual mySite-http {
   snat automap
   pool my-http
   destination w.x.y.z:http
   ip protocol tcp
virtual mySite-https {
   snat automap
   pool my-https
   destination w.x.y.z:https
   ip protocol tcp
If you use a port 0 pool, you can share the pool (and the related cookie) between 2 virtual servers and set both to use cookie insert persistence.
For the HTTP virtual server, no iRule would be required, since the port will pass through unchanged and the persistence will work as usual.
For the HTTPS virtual, you’ll need an iRule to look for an existing cookie, decode the server IP and select the correct pool member specifying port 81.
The Persistence Cookie Logger iRule (Click here) has the logic to extract the IP address of the node.
You can use the node command (Click here) to specify a node by IP + port. (Logic to catch a dead server can be added in LB_FAILED event as demonstrated there.)
HTH
/deb
A related suggestion…
If you’re able to use only HTTP on the back end to the servers, you could define the pool members on the same HTTP port and avoid using an iRule altogether. Just the two VIPs, the same cookie insert persistence profile and the same pool would work.
And if you wanted to use one VIP on port 0, with one cookie persist profile and one pool with the members defined on an HTTP port, you could use a rule like this:
when CLIENT_ACCEPTED {
    Make decisions based on the destination port
   switch [TCP::local_port] {
      80 {
          Need to disable client SSL for HTTP requests
         SSL::disable
      443 {
          Do nothing, request will be decrypted and sent to pool
      default {
          Reset the request as it's not to an allowed port
         reject
Aaron
Hi tried the solution from deb. The only problem is, if a user connect the first time direct with https, then the lb can’t find any cookie and he never add one.
when RULE_INIT {
   see SOL6917 for cookie encoding details: https://tech.f5.com/home/solutions/sol6917.html
  set ::myCookieName BigIP_cash_cms
  set ::debug 1
 grab encoded cookie value & parse into relevant pieces
if {[HTTP::cookie exists $::myCookieName]}{
scan [HTTP::cookie $::myCookieName] "%d.%d.%d" myIpE myPortE unused
if {$::debug != 0}{log local0. "myIpD=$myIpE   myPortE=$myPortE  unused=$unused"}
 calculate IP
set myIpH [format %x $myIpE]
if {$::debug != 0}{log local0. "myIpH=$myIpH"}
set myIpD1 [expr 0x[substr $myIpH 6 2]]
set myIpD2 [expr 0x[substr $myIpH 4 2]]
set myIpD3 [expr 0x[substr $myIpH 2 2]]
set myIpD4 [expr 0x[substr $myIpH 0 2]]
set myIpD "$myIpD1.$myIpD2.$myIpD3.$myIpD4"
if {$::debug != 0}{log local0. "myIpD=$myIpD"}
 set node
node $myIpD 81
if {$::debug != 0}{log local0. "cookie $::myCookieName not found"}
so i thought that i can add a cookie on the response. That’s working not bad, but if I change after in the same session to http, it doesn’t work. I can’t find the failure.
when HTTP_RESPONSE {
 add session cookie to response
if {$::debug != 0}{log local0. "add cookie $::myCookieName to response"}
if {$::debug != 0}{log local0. "cookie $::myCookieName for server [LB::server addr]"}
scan [LB::server addr] "%d.%d.%d.%d" myIP1 myIP2 myIP3 myIP4
set myCookieValue "[format %x $myIP4][format %x $myIP3][format %x $myIP2][format %x $myIP1]"
HTTP::cookie insert name $::myCookieName value "[expr 0x$myCookieValue].0.0000"
when LB_SELECTED {
 for the case, that no cookie was available in "HTTP:REQUEST" change here to port 81
set myLBPort [LB::server port]
if {$::debug != 0}{log local0. "myLBAddr=[LB::server addr] mylBPort=$myLBPort"}
if {$myLBPort == 0}{
if {$::debug != 0}{log local0. "myLBPort is 0"}
set myLBAddr [LB::server addr]
node $myLBAddr 81
LB::reselect
The solution from hoolio only works if http and https traffic are forwarded to port 80. But not if https traffic must be forwarded to port 81
Ah, I left out one critical detail: to use cookie persistence on HTTPS, you have decrypt & re-encrypt the traffic (apply a clientssl and serverssl profile to the virtual server) otherwise the cookie will never be seen (it will be encrypted and unreadable by LTM)
/deb
