Redirect depending 2nd level
Hello
I would like to redirect http requests to a pool depending on the second level URI
Let me explain myself
http://www.mycompany.com/finances/dev
Depending on dev in this case it should be send to a pool1
I try this irule first part(which affects to the first level) works fine but the second part it doenst works
set uri [string tolower [HTTP::uri]]
if { $uri starts_with “/tics”
or $uri starts_with “/customer”
or $uri contains “jdbc”
pool pool_www
} elseif { $uri starts_with “/finances/dev” } {
pool pool_dev
HTTP::redirect “http://www.f5.com/”
Does anybody knows what im doing wrong?
The Server replies to http://local_IP/finances/dev
Thanks in advance
Nacho de Aguinaga
Can you explain what request you are making, what is happening and how you want to handle the request instead?
You can add logging to the rule to get additional detail on what is happening:
   log local0. "[IP::client_addr] - \$uri: $uri"
   if { $uri starts_with "/tics" or $uri starts_with "/customer" or $uri contains "jdbc"}{
      log local0. "[IP::client_addr] - matched test for pool_www"
      pool pool_www
   } elseif { $uri starts_with "/finances/dev" } {
      log local0. "[IP::client_addr] - matched test for pool_dev"
      pool pool_dev
      log local0. "[IP::client_addr] - default: redirected"
      HTTP::redirect "http://www.f5.com/"
Aaron
