Hi
I have configured the new F5, but could not ping the F5 external Interface, but I can take https using same external ip. I can ping management and internal ip, Any clue what will be the issue.
Hi
Hi Rajendran2002,
Are you trying to ping from the other side of the interface on the F5 or are ping from the same side of the interface as the F5 external interface?
Hello,
It may be a port lockdown issue.
To test it, you can set your selfip settings for portlockdown to all
Hi Bhattman
Am trying to ping from other subnet(Ex 10.32.127.0) and F5 subnet (10.32.76.0), ICMP is allowed in the passing firewall. But F5 does not respond, But I could https from the 10.32.127.0 .
Hi Yann
I did verified setting the port lockdown to all , But no sucess
