random letter generator
Problem this snippet solves:
This iRule demonstrates how to generate a string of pseudo-random letters. rand() doesn’t generate cryptographically secure output. If you need this, use the CRYPTO commands.
Code :
when RULE_INIT {
   # Number of random letters to generate
   set count 100
   # Create a list of the letters indexed 0 through 25
   set letters [ list a b c d e f g h i j k l m n o p q r s t u v w x y z ]
   # Initialize a variable to store the random letters in
   set random ""
   # Loop through X times where X is the number of random letters to generate
   for { set i 1 } { $i < $count } { incr i } {
      # Generate a random number between 0 and 1, using rand()
      # Multiply that by 26 to get a number representing a letter
      # Use int to trim off the decimal value
      # set rand [expr { int (rand() * 26) }]
      # append random [lindex $letters $rand]
      # Or in one command:
      append random [lindex $letters [expr { int (rand() * 26) }]]
   log local0. "Random letters: $random"
