Hi Folks,
I’d like to know if someone already had figured out a stable solution to enumerate procedures and then access the body of a given procedure?
The commands [info procs proc_*] and [info body proc_name] doesn’t seem to work for iRule based procedures.
Cheers, Kai
Hi folks,
in the meantime I’ve found a “good enough” workaround to locate the procedures and fetch their bodys. Its a kinda arkward and intrusive TCL hack, but its able to support my current requirements.
Below is a stripped down version of the workaround:
Script: IRULE_1
when RULE_INIT priority 500 {
set static::local_procs(IRULE_1::PROC_NAME_A) ""
proc PROC_NAME_A {} {
uplevel {
iControl will verify this TCL code
Script: IRULE_2
set static::local_procs(IRULE_2::PROC_NAME_B) ""
proc PROC_NAME_B {} {
uplevel {
Script: IRULE_3
when RULE_INIT priority 999 {
if { not ( [info commands uplevel_ren] ) } then {
set static::cmd(rename_uplevel) {
rename uplevel uplevel_ren
interp alias {} uplevel {} return
eval $static::cmd(rename_uplevel)
foreach local_proc [array names static::local_procs] {
eval "set static::local_procedures_body($local_proc) \[call $local_proc\]"
if { [info commands uplevel_ren] } then {
set static::cmd(restore_uplevel) {
rename uplevel_ren uplevel
eval $static::cmd(restore_uplevel)
If someone figures out a less intrusive method to access the body of a given procedure, then please let me know. Thanks in advance!
Cheers, Kai
