Question about ASM Solution
Hi all
I have question about ASM solution.
F5 ASM policy can be deploy as per virtual IP then if there are virtual hosts that have many Web site then F5 policy can not be apply.is it true?
Please help to answer the question.
Best Regards,
Sorn47
If the web server virtual hosts resolve to the same IP address:port, you could use one ASM policy on that single LTM virtual server. Or if the virtual hosts resolve to different IP address:port’s you could add the same ASM policy instance on multiple LTM virtual servers. Hopefully this makes sense.
Aaron
Hi Sorn,
I am not sure I understand your question, can you please help me with describing your use case and your concern?
BIG-IP-ASM is super flexible in the various ways it can apply a policy so I am sure that we could find a solution to your use case.
About my question is ASM standalone solution.
Ex. I have 3 applications in one server. Can I create 3 policy for 3 application?
please advice.
Best Regards,
Sorn47
As Ido says, it’s very flexible. You can have multiple policies per LTM virtual server (using multiple HTTP classes with ASM enabled) or one policy for multiple LTM virtual servers (using a single HTTP class with ASM enabled).
Aaron
Check out 404 Page not found | BIG-IP Documentation
Thanks,
Tom.
Thanks for you kinly suggestion.
Best Regards,
Sorn47
