The ProxyPass ver 10.9 has issues on retrieving the information stored on the data groups I got this error when trying to load the iRule (in the GUI the iRule loads but when I try the command tmsh load sys config not):
Code[root@asmjs2:Active:Standalone] config zmore /var/log/ltm* | grep missing
Code Jan 15 14:37:18 asmjs2 err mcpd[7566]: 01070151:3: Rule [/Common/rule_proxypass] error: /Common/rule_proxypass:79: error: [parse error: missing close-bracket][[URI::basename [virtual name]" if { $static::ProxyPassDebug > 1 } { log local0. "[virtual name]: [IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port]" }]
The line 75 has this command:
Code set serverside [string trimleft [getfield $ppass " " 2 ] "{" ]
