We are trying to connect to a remote site via F5 APM through a proxy. It works fine when accessing via the web portal, but we cannot configure the Command Line Client for Linux to use that proxy.
Would you know how to do that?
Thanks in advance!
Thanks in advance!
never tried this and don’t have a linux server ready to test. but i assume you tried setting the proxy server via export http_proxy ? and you have check the commandline options on the f5 apm linux client?
if all that has been tried i would say contact support, they can give a final verdict and probably point you to a RFE if it exists. please do report back here.
