Problem with implementing iApp f5.http
Hi eneryone, When try to implementing on my f5 with version 11.6.0 HF5, When I create and use text the template f5.http to create a basic http aplication show thi messages, and don´t work that sheet. I areciate your help.
script did not successfully complete: (field not present: “address” while executing “tmsh::get_field_value $node address” (procedure “iapp::destination” line 104) invoked from within “iapp::destination $::pool__addr $::pool__port” invoked from within “iapp::conf create ltm virtual ${app}_vs destination [iapp::destination $::pool__addr $::pool__port] mask $mask $vs_params ip-protocol tcp mirror …” invoked from within “subst $substa_out” invoked from within “if { [info exists [set substa_in]] } { set substa_out [subst $$substa_in] set substa_out [subst $substa_out] } else { …” (“uplevel” body line 3) invoked from within “uplevel { append ::substa_debug “\n$substa_in” if { [info exists [set substa_in]] } { set substa_out [subst $$substa_in] …” (procedure “iapp::substa” line 9) invoked from within “iapp::substa vs_arr($secure_client,$do_redirect)” (procedure “v11_4_main” line 444) invoked from within “v11_4_main” invoked from within “subst $substa_out” invoked from within “if { [info exists [set substa_in]] } { set substa_out [subst $$substa_in] set substa_out [subst $substa_out] } else { …” (“uplevel” body line 3) invoked from within “uplevel { append ::substa_debug “\n$substa_in” if { [info exists [set substa_in]] } { set substa_out [subst $$substa_in] …” (procedure “iapp::substa” line 9) invoked from within “iapp::substa main($do_v11_3,$upgrade,$downgrade)” line:942)
did you use the iApp that came with the system? did you fill in a node address? didn’t leave one empty or such?
Hi Jorge, if you have any nodes that use an FQDN instead of an IP address, you will get this error. If you deploy the backported version of f5.http from DevCentral - An F5 Technical Community, do you get the same error?
thanks
