Possible Errors F5 can generate
Hi Team,
Is there any document detailing all the possible errors that we can found in the /var/log/ltm file.
For example, which error will F5 send if a power supply got failed?
You can see these events in the SNMP MIB list. These are the events that get logged to syslog. The mibs can be downloaded if you click on the About Tab in the GUI and scroll down to Downloads SNMP MIBs
The compressed files listed below contain all SNMP MIBs related to the BIG-IP system.
Download F5 MIBs (mibs_f5.tar.gz)
Download NET-SNMP MIBs (mibs_netsnmp.tar.gz)
https://support.f5.com/kb/en-us/solutions/public/13000/300/sol13322.html
that will help up to a degree, but I doubt you will get a full list somewhere.
