Port Translation
I’ve been struggling all day with this one… I have two separate problems and not sure if they are related.
1. I have a VS configured to listen on an IP and on port HTTP 80. I have it attached to a pool with a few webservers in it. The webservers are serving on port TCP 8080 instead. I have the “Port Translation” checkbox checked under the VS settings. It appears that it is not working.
2. The URL that points to that VIP is “http://test1.phly.net”. When you hit that URL and it gets passed along to the pool member, the server replies with an HTTP 301 redirect and replies with its own hostname instead “http://server1.phly.net”. We want to find when a 301 redirect comes in and replace the hostname with the original URL of “http://test1.phly.net”. I’ve been working with iRules but couldn’t really get anything working as of yet. One of the problems in the iRule is that we don’t want to statically set what to swap out in the HTTP Header. This needs to be dynamic because of all of the possible pool members that it can have.
Any ideas or suggestions?
I’m on version 10.1.0.
You will need to find what is sending the 301 Redirect (sounds like the server(s)) and stop it there.
This should capture the redirect from the server and change the “server1” value to “test1”. If the server is indeed sending this redirect back to the requestor, then this iRule will create and endless loop between the two.
when HTTP_RESPONSE {
if { [HTTP::is_redirect] } {
HTTP::header replace Location [ string map  {"server1" "test1"} [HTTP::header Location] ]
Port translation is fairly bullet proof. I’d guess the issue is not with the port translation, but with the application’s references to itself within the HTTP.
Here’s something to start with to replace the domain in redirects. If this doesn’t fix all of the issues, try using a browser plugin like HttpFox for Firefox or Fiddler for IE to check the web app response headers and/or payloads.
    Check if response is a redirect
   if {[HTTP::is_redirect]}{
       Replace the hostname in the Location header with the external FQDN
      HTTP::header replace Location "[string map -nocase [URI::host [HTTP::header Location]] test1.phly.net" [HTTP::header Location]]
Aaron
Michael I was using that same iRule to test, the only problem is I’d have to statically define the server hostnames to replace. I want to keep that part dynamic so I don’t have to update the iRule everytime they add a server to the pool.
Aaron, I like your script because it’s grabbing the host by URI::host, but that iRule doesn’t seem to be working. I also ran into a syntax error when I tried it.
Sorry, it was a misplaced double quote. Can you try this:
      HTTP::header replace Location [string map -nocase "[URI::host [HTTP::header Location]] test1.phly.net" [HTTP::header Location]]
Aaron
That worked…
I’ve added to it to make it even more dynamic. I’m grabbing the FQDN from the HTTP request and changing the hostname to it.
set ext_fqdn "[HTTP::host]"
      HTTP::header replace Location [string map -nocase "[URI::host [HTTP::header Location]] $ext_fqdn" [HTTP::header Location]]
I also had a question… Isn’t this iRule the same thing as changing the “Redirect Rewrite” under the Profile?
Nice work.
With the Redirect Rewrite option on an HTTP profile, you can rewrite http:// to https:// or the node address to the VS address. But you can’t replace the hostname in a redirect with the VS address or the hostname the client requested.
Aaron
Ok. Thanks for that explanation.
So the code we are working with above only works in Firefox. IE gives me a page cannot be displayed and Google Chrome just shows me nothing. Firefox works like a champ though. ???
Do you see any errors in /var/log/ltm when testing with IE or Chrome? Can you use a browser plugin like Fiddler to see which request the failure is occurring on?
Aaron
Well here’s the crazy part. In the end they want to replace the hostname in the redirect to keep the common URI. They also want the VIP to be on port HTTP 80 while the backend pool servers are on port 8080. I just changed my VS to listen on 80 instead of 8080 and wham. All 3 browsers now work with the port translation and the hostname change in the iRule we made. Weird. Not sure why doing the port translation “fixed” the other browser problems.
I agree with Hoolio in his suggestion of using something like Fiddler 2 (Web Debugging Proxy and Troubleshooting Tools | Fiddler), it is the only Web Debugging tool that I know of that supports debugging HTTPS traffic.
I would also recommend HTTPWatch Basic Edition (Download | HttpWatch) which plugs into IE and Firefox (although I haven’t been impressed with it in Firefox).
Either tool can greatly assist in writing iRules.
Yes I grabbed Fiddler to help me see what was going on. On a separate situation, is there a way to create this same type of iRule but instead of looking into the HTTP header for the URI, can you look in the HTML body and replace the URI’s there?
The most efficient way to replace payload content is a blank stream profile and a STREAM::expression based iRule. See the wiki page for examples:
http://devcentral.f5.com/wiki/default.aspx/iRules/stream\_\_expression
Aaron
You can replace anything in the Header if you know specifically what your looking for and want to replace it with.
The first example that I gave searches for a string “server1” and replaces it with a string “test1”.
Or you could do something like what hoolio did and replace the URI instead of the Host:
Replace Host (URI::host) = http://devcentral.f5.com/wiki/default.aspx/iRules/URI__host.html
Replace Path (URI::path) = http://devcentral.f5.com/wiki/default.aspx/iRules/URI__path.html
      HTTP::header replace Location [string map -nocase "[URI::path [HTTP::header Location]] /some/value/index.html" [HTTP::header Location]]
If you are looking to do replacements in the body, you can do that too. The Stream Profile or Stream Expression is a good place to look for ideas:
http://devcentral.f5.com/wiki/default.aspx/iRules/stream__expression
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/241/iControl-101--18--Stream-Profile.aspx
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/101/LTM-stream-profile-Multiple-replacements-regular-expressions.aspx
