OWA integrated authentication to forms
Hello, Need a suggestion of away for user to attempt to login to a IA member server and if the authentication fails have the users connection be moved to another pool. i.e. the forms pool. Any Ideas?
Hi Brian,
Can you use a browser plugin like Fiddler to record a client going through the NTLM auth and it failing? You could then use an iRule to try to look for the IA auth failure and retry the HTTP request to a second pool using HTTP::retry (Click Here).
Aaron
