I’m using BigIP Web Accelerator to cache from IIS
but when I try to go to secure and
HTTP_RESPONSE return HTTP::status 401 then my browser return ERROR_INTERNET_CONNECTION_RESET result.
This could be a result of a couple of configuration issues:
1) SSL configuration on the VS
2) SNAT not be configured
3) Address translation and port translation not being enabled
I would recommend you open a case with support if the issue is not resolved by one of the above.
