Hi There,
I have two pools each with two nodes - all mysql servers. Both pools are using an external monitor script with an iRule for Single Node Persistence - The rule looks like this: when CLIENT_ACCEPTED { persist uie 1 }
The thing is that my nodes in pool number 2 are dependent on nodes in pool number 1:
Node1 in pool 2 is dependent on node 1 in pool 1 and node 2 in pool 2 is dependent on node 2 in pool 1.
So this is the behavior I am looking for: I need a switch over in pool 2, if node 1 in pool 1 fails and the same for node 2. In another word, if node 1 on pool 1 goes down and F5 switches to node 2, I also need my pool number 2 to switch to node 2.
I hope this is clear.
Can someone please give me some guidelines in terms of the best way to achieve this?
Thanks,
Ali
