Nesting operations within an iRule
I have 9000+ client subnets grouped into roughly 5 ranges. For example, is it possible to have a single iRule that performs the following evaluation:
  • if client is in 172.16.0.0/16 then pool 1
  • if client is in 172.17.0.0/16 then pool 2
  • if client is in 172.18.0.0/16 then pool 3
If you could map some range digit to pool name it would be easy. Alternative may be to use a data group to do some mapping.
Simple if/elseif structure. I sure you could use tables/data group, but I never used them, so I don’t know how.
if {[IP::addr [IP::client_addr]/16 equals 172.16.0.0]} {
    pool POOL1
} elseif {[IP::addr [IP::client_addr]/16 equals 172.17.0.0]} {
    pool POOL2
} elseif {[IP::addr [IP::client_addr]/16 equals 172.18.0.0]} {
    pool POOL3
pool DEFAULT
This is typically easily done with an “ip” type datagroup. You can probably write a small script to create an empty datagroup and then add all the records in it. The key would be the CIDR network and the value would be the pool name.
The iRule snippet you need is
if { [class match [client_addr] equals ] } {
        set poolname [class match -value [client_addr] equals  ]
        pool $poolname
        pool default-pool
Here is a sample data-group
ltm data-group internal dg_1 {
    records {
        10.0.0.0/8 {
            data pool1
    type ip
This is may be more scholastic/less practical for your use, but you could split into roughly 5 equal parts with a one-liner where pools are labled pool0-4.
pool "pool[expr [getfield [IP::client_addr] "." 2] % 5]"
Thanks to all, the variety of solutions should cover my requirements.
