Monitoring FirePass 4100 Controller
Hello,
Do you know if it possible to monitor fans and temp sensors via SNMP requests on this device ?
Looking for informations since a couple of hours, I’m pessimist…
Thanks.
Hi rodjeur,
I haven’t worked with the 4100s specifically, but I would download the MIBs for that version of FirePass and sift through them. A simple ‘egrep -i ‘(fan|temp|sens)’ *.mib’ should expose the metrics you are looking for. Here is a support article on viewing the MIBs: 404 Page not found | BIG-IP Documentation
Hope this helps,
George
