Is there a way anyone has found to get an email notification if a redundant pair failover of BigIP occurs?
thanks
thanks
Edit /etc/alertd/alert.conf, bold lines added to the default file contents
alert BIGIP_SOD_SODERR_SOD_STANDBY {
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.14";
lcdwarn description="Unit going standby." priority="0"
email toaddress="LTM-alert@mydomain.com"
fromaddress="LTM1@mydomain.com"
body="LTM Failover event occured: Unit going to standby"
alert BIGIP_SOD_SODERR_SOD_ACTIVE {
snmptrap OID=".1.3.6.1.4.1.3375.2.4.0.15";
lcdwarn description="Unit going Active." priority="0"
body="LTM Failover event occured: Unit going to active"
This assumes you have postfix configured to forward mail to your relay.
For more details on alertd, Click here
For details on configuring postfix, Click here
Small nit… It should be
lcdwarn description="Unit going standby." priority="0";
lcdwarn description="Unit going Active." priority="0";
Note the ‘;’ (Semi-Colon) between the second alert (lcdwarn) and the third (email). (You need a semi-colon between each alert). Not obvious unfortunately. The alertd just logs into ltm that there’s a problem at the email line otherwise.
yep, you’re right, I missed that. Thanks!
While configured this, we are getting the below email “Subject: 010c0018”. Is there any way we can change the subjet of the email?
From: root [mailto:root@lb-lab1.test.com] Sent: Tuesday, June 5, 2018 4:58 PM To: mazam@test.com Subject: 010c0018
