Monitor HTTPS on Version 11
I upgraded to an F5 LTM version 11.2.1 HF4, from version 10.2.0
I have a problem with multiple monitors in Pools with members to port 4443.
The monitor is as follows:
Type: HTTPS
Send String: GET / test / index.html HTTP/1.1 \ r \ nHost: 10.X.XXX.XX: 4443 \ r \ n \ r \ n
Recive string: 200
Cipher list: DEFAULT: + SHA + DES +3 kEDH
Any idea what might be going to not work in version 11?
Thanks a lot!
A. DIEZMA
i think the send string is correct. have you tried ssldump?
I have not tried. In version 10 it’s worked but not in version 11.2.1.
Thanks!
Hi;
I modified the monitor with this:
GET /test/index.html HTTP/1.1\r\nHost: 10.8.138.21:4443\r\nConnection: Close\r\n\r\n
but, not works…**bleep**! hahaha I’m going mad…
The openssl probe is correct:
openssl s_client -connect 10.8.138.21%3:4443
CONNECTED(00000003)
depth=1 /C=ES/O=FNMT/OU=FNMT Clase 2 CA
verify error:num=19:self signed certificate in certificate chain
verify return:0
Certificate chain
0 s:/C=ES/O=FNMT/OU=FNMT Clase 2 CA/OU=BLABLA/OU=00000000/CN=xxx.yyy.zzz.eee.ccc
i:/C=ES/O=FNMT/OU=FNMT Clase 2 CA
1 s:/C=ES/O=FNMT/OU=FNMT Clase 2 CA
Server certificate
-----BEGIN CERTIFICATE-----
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx==
-----END CERTIFICATE-----
subject=/C=ES/O=FNMT/OU=FNMT Clase 2 CA/OU=BLABLA/OU=00000000/CN=xxx.yyy.zzz.eee.ccc
issuer=/C=ES/O=FNMT/OU=FNMT Clase 2 CA
No client certificate CA names sent
SSL handshake has read 1960 bytes and written 351 bytes
New, TLSv1/SSLv3, Cipher is DES-CBC3-SHA
Server public key is 1024 bit
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : SSLv3
Cipher : DES-CBC3-SHA
Session-ID: FXXXXXXXXXXXXBEXXXXXXXXC
Session-ID-ctx:
Master-Key: XXXXXXXXXXXXXxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxXXXXXXXXXXXXXXXXXXXXXXXXXXX
Key-Arg : None
Start Time: 1366801496
Timeout : 300 (sec)
Verify return code: 19 (self signed certificate in certificate chain)
Host: 10.8.138.15:4443
HTTP/1.1 200 OK
ETag: “17b9a-2f-4a49e886”
Content-Type: text/html
Server: Oracle-Application-Server-10g/10.1.3.1.0 Oracle-HTTP-Server OracleAS-Web-Cache-10g/10.1.2.2.0 (N;ecid=325862908542,0)
Last-Modified: Tue, 30 Jun 2009 10:27:18 GMT
Content-Length: 47
Date: Wed, 24 Apr 2013 11:05:01 GMT
Accept-Ranges: bytes
almendra1 10.1.3. OK
closed
Any idea???
A. Diezma
Hi;
CONNECTED(00000003)
verify return:0
Certificate chain
Server certificate
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : SSLv3
Session-ID-ctx:
Key-Arg : None
Timeout : 300 (sec)
HTTP/1.1 200 OK
ETag: "17b9a-2f-4a49e886"
Content-Length: 47
closed
Any idea???
A. Diezma
I’d suggest you remove :4443 I don’t see the need for it at all if the monitor is sending the request to the correct port
but, not works…Damn! hahaha I’m going mad…
The openssl probe is correct: have you tried tcpdump/ssldump on the health monitor traffic? what was it different from the openssl s_client?
