One of our partners is ready to provide the UCS file required to build the new VE Load Balancer, as they have concerns that the UCS contains sensitive credentials. Is there an option to generate and share a UCS after removing the credentials?
If not, can the new load balancer be built using the Local Traffic Manager configuration file (bigip.conf), which they are willing to share? Based on my experience, using only the bigip.conf file would require most of the configuration to be recreated manually. Is there any tool available that can convert the Local Traffic Manager (bigip.conf) configuration into a UCS file, or into another format that can be easily imported into an F5 device?
Thanks,
Nile
