I am a novice with F5 BigIP.
I am looking for a procedure as to how I can migrate my config from my existing configuration to the hardware appliance.
F5-VE has interface names as 1.1,1.2,1.3… and i2000 series interface names are 1.0 2.0 - I am not sure where and how to edit the base config file.
Hi HarishSolanki,
For VM:
1. Backup UCS
save /sys ucs /var/local/UCS/MyUCS.ucs no-private-key
2. Download UCS
3. Look f5mku
f5mku -K
For i2000:
1. Upload UCS to /var/local/ucs folder
2. Create temp folder in /var/local/ucs
cd /var/local/ucs
mkdir abc
cd abc
3. Unzip UCS
tar -xzf /var/local/ucs/MyUCS.ucs
4. Open bigip_base.conf folder
nano config/bigip_base.conf
# or
vi config/bigip_base.conf
5. Change all interface names in bigip_base.conf
1.1 > 1.0
1.2 > 2.0
1.3 > 3.0
6. Save bigip_base.conf
7. Zip files
tar -czf /var/local/ucs/newMyUCS.ucs *
8. Enter vm’s f5mku value
f5mku -r <vm f5mku value>
9. Restore UCS
tmsh
load sys ucs newMyUCS.ucs no-license no-platform-check
Article for f5mku: https://support.f5.com/csp/article/K9420
Want to clear one confusion. In step 4; using nano \config\bigip_base.conf is opening the original file of the physical appliance where else if I open the folder config and then open the bigip_base.conf; then it opens the conf file that was unzipped and this file I can see interfaces 1.1 and so on.
You’re right. I change step 4.
Correctly command is without slash:
# or
Used the procedure from the following link and it seems to have worked. Will do the same with the standby unit and will test it to make sure fail over works.
Thanks EAA… really appreciate your help.
The best solution is to :
- Create an archive on VE
- Configure i2000 with different IP address than VE
- switch i2000 to OFFLINE mode
- Configure VE and hardware with sync and failover network on one self IP
- move Self IP (used for sync) to Allow default on both systems
- add i2000 in VE trust peers --> Master key is synchronized to new peer
- create a device group sync-failover with both systems
- Sync VE to i2000 --> all cluster configuration is synced, including routes, dns, vs, pools
- failover to i2000
- disconnect VE vNICs (to fallback, you can restore archive… it will remove cluster configuration)
- remove VE and i2000 from Device group
- Remove the VE from i2000 device trust
- The i2000 is now in Standalone mode
- move Self IP (used for sync) to Allow None
This solution requires both system to be in same TMOS version, same release Point.
