I have a VIP on which cookie persistence is enabled. The cookie header contains a lot of other cookies that my browser passes. Is it possible to trim some of those cookies and pass only the desired ones to my servers?
Yes, the easiest way is to use an irule that removes any un-wanted cookies.
HTTP::cookie remove
Absolutely, and it’s easy enough with iRules provided you know which cookies should be removed:
HTTP::cookie remove
If you don’t know exactly what cookies you want to remove but instead know what cookies you want to keep it’s a bit more complicated, because then you need to loop through all the cookies and check if it’s an allowed cookie or not. If this is the case I can make an example for you if you want.
Thanks for the responses, is it possible to get the value of a single cookie with name say “test-cookie” from the list of cookies and replace the entire cookie header with just this one? Henrik can you point me to such an irule please?
Sure, it would look something like this, might be typos since I’m doing this from the top of my head:
foreach c_name [HTTP::cookie names] {
if { !( [HTTP::cookie $c_name] eq "test-cookie" ) }{
HTTP::cookie remove $c_name
This should remove all cookies except for the “test-cookie” you want.
set sessionCookies [ HTTP::cookie names ]
foreach mycookie $sessionCookies {
if { not ($mycookie equals "test-cookie") }{
HTTP::cookie remove $mycookie
Also, if you want to have a list of allowed cookies, create a data group containing that list named “allowedCookies_dg” and use an iRule like this. when HTTP_REQUEST { set sessionCookies [ HTTP::cookie names ] foreach mycookie $sessionCookies { if { not ( [class match $mycookie equals “allowedCookie_dg”]) }{ HTTP::cookie remove $mycookie } } }
Thanks a lot, I will try these out. Is there an article on devcentral which points to various things that can be done with a HTTP::cookie like getting the names, rewriting, removing etc., ?
