LTM TACACS source interface
Is there a way to set a source interface that TACACS will use? Ideally I’d like to set it to the management interface. Thanks.
Hi Ben,
Yes, you can do this by creating a management route from the CLI using bigpipe or tmsh:
b mgmt route 10.10.10.0/24 gateway 172.24.74.62
tmsh create sys management-route 10.10.10.0/24 gateway 172.24.74.62
Aaron
I tried as suggested adding a management route for the Tacacs server, but the source IP address of Tacacs+ requiests is always the Active Slot management IP. Is there any way for the source IP to be the cluster IP instead of the slot IP?
Thanks, Lucio
