LTM 9.4.2+ Custom Syslog errors when bpsh used
Followed information in the article LTM 9.4.2+: Custom Syslog configuration to have logs go to my syslog server.
Followed the process of creating a file and then using bpsh.
but when i do I end up with errors. What am I doing wrong here??
It should be simple to send a class of messages to an external logging host.
Thanks.
file is to send local0 LTM messages. the file contents and console shows:
[bhhanson@f5ndcint1b:Standby] ~ cat syslog-skinner.inc
syslog include "
destination remote_server {
udp(\“172.17.1.1\” port (514)sy);
local0.*/var/log/ltm
filter f_local0 {
facility(local0);
filter f_no_audit {
not match(\“AUDIT\”);
destination d_ltm {
file(\“/var/log/ltm\” create_dirs(yes));
log {
source(local);
filter(f_local0);
filter(f_no_audit);
destination(d_ltm);
destionation(remote_server);
[bhhanson@f5ndcint1b:Standby] ~ bpsh < syslog-skinner.inc
BIGpipe unknown operation error:
01070920:3: Application error for confpp: STDERR/STDOUT text begins
Stopping syslog-ng: [ OK ]
Starting syslog-ng: \\Warning: Unknown facility; facility=‘s_httpd’
syntax error at 515
[FAILED]
STDERR/STDOUT text ends
Oct 27 12:56:42 f5ndcint1b.healthpartners.com confpp[7267]: reconfig command FAILURE for unix_config_syslog returned:
‘/etc/init.d/syslog-ng restart 2>&1’
Stopping syslog-ng: [FAILED]
Starting syslog-ng: [ OK ]
I’m not sure what the error about s_httpd is. Do you have a facility set to an invalid name?
Also, it looks like there is a typo in destination:
This line also looks incorrect:
Aaron
gosh. *embarassed* the ‘sy’ was not supposed to be there. bad paste/edit. i think destination does not have an ‘o’ in it.
right.. this is ‘out of the box’ and the first time I have tried to use this process. So where does this all mess up.
maybe time to ask support?
If you’re following the steps in the article and they’re not working, F5 Support should be able to help troubleshoot the issue.
Aaron
