Login Enforcement Issue
I’ve got issue with Login enforcement, where I can’t access authorized URL when I was logging off(which is normal), but also i can’t access it when login from login page, and also gives me default response page although i customized it and shown customized for all other Violations.
bit late but i’d probably check the access validation setting on the Login URL you’ve configured. It may be that it’s not quite right i.e. a 302 status code when a 200 is configured (just as an example).
If you’ve sorted this now then please feedback the solution.
Rgds
N
Sorry, did you specifically create a custom Login Page Response page in the Blocking Response Pages section?
Rgds
N
