Loadbalance redirects
Were migrating an internet application behind a BIGIP,
it has specfic url requirements so we have a simple iRule on a virtual server, all working fine.
rule redirect_to_webservers {
HTTP::redirect https://www1.server.com
But this is putting a load on www1 server, would like todo the following
rule redirect_to_webserver {
Pick a server 1 2 or 3 then {
case 1
case 2
HTTP::redirect https://www2.server.com
case 3
HTTP::redirect https://www3.server.com
Can’t figure out how i would make the iRule pick a server, something simple would do or maybe generate a random value based on the clients ip or date/time, then use this value to pick a server.
Any ideas ?
Well, my first recommendation, if it’s possible, would be to create a pool with the three systems in it, and just let BIG-IP load balance normally to that pool. You wouldn’t need an iRule at all for this.
If, for some reason, you can’t use a pool, and need the explicit redirect in the iRule, then you’d just need something like a simple counter to spread out the requests in a round robin fashion, like this:
*edited to include unruley’s suggestion below*
when RULE_INIT {
  set ::n 1
  if { $::n >= 4 } {
    set n 1
  HTTP::redirect "https://www$n.server.com"
  incr ::n
-Colin
BTW, you probably want a :: in front of n, so that it is in the global namespace.
Thanks Guys, see the below rule we put together…
rule lb_rule {
when RULE_INIT {
set ::lb_counter 1
log local0. “Rule Starting lb_counter is $::lb_counter”
log local0. “HTTP Request counter is $::lb_counter”
if {$::lb_counter == 1} {
set ::lb_counter 2
log “Logging to server1”
HTTP::redirect “https://server1.f5.com
elseif {$::lb_counter == 2} {
set ::lb_counter 3
log local0. “Logging to server2”
HTTP::redirect “https://server2.f5.com
elseif {$::lb_counter == 3} {
set ::lb_counter 1
log local0. “Logging to server3”
HTTP::redirect “https://server3.f5.com
Nice work! I always enjoy seeing the result of the discussions here on DevCentral. Thanks for taking the time to come back and post your rule, it’s much appreciated!
-Colin
Hello everyone.
First, I’m not belingual so excuse my English.
In my configuration, I have one pool named all_support_pool_fla and 4 servers. My goal is to share http and ftp traffic like this : two servers deal whith http traffic and two others deal whith ftp traffic. But all the servers are in the pool all_support_pool_fla.
Members of my_pool had been defined like that :
172.20.50.100:80
172.20.50.100:21
172.20.50.101:80
172.20.50.101:21
172.20.50.102:80
172.20.50.102:21
172.20.50.103:80
172.20.50.103:21
I want to create an iRule which can share traffic between them. I know this can be done easily by create two pools, but I like to make my life harder:P
By taking exemple on this iRule I made another one :
when RULE_INIT {
set ::compteur_http 1
set ::compteur_ftp 1
if { [TCP::local_port] eq “80” } {
if { $::compteur_http == 1 } {
set ::compteur_http 2
pool all_support_pool_fla member 172.20.50.100:80
elseif { $::compteur_http == 2 } {
pool all_support_pool_fla member 172.20.50.101:80
if { [TCP::local_port] eq “21” } {
if { $::compteur_ftp == 1 } {
set ::compteur_ftp 2
pool all_support_pool_fla member 172.20.50.102:21
elseif { $::compteur_ftp == 2 } {
pool all_support_pool_fla member 172.20.50.103:21
But there is two problems. First, FTP traffic doesn’t run. I think this is because I used this in a block with HTTP_REQUEST. Should I use CLIENT_ACCEPTED or something else?
And secondly this iRule is run each time a client connect to the virtual server, so every time the client is directed to the server 172.20.50.100 (for HTTP of course), and I want to use a load balancing like Round Robin (no more complication it’s useless:D) in the iRule.
Please help me.
Thanks.
You are correct that FTP will not function properly within an HTTP virtual server.
The good news is that the load balancing you want can be accomplished using built-in product features instead of a rule.
You’ll need to create 2 pools, one containing just the webservers, the other containing just the ftp servers. Set the load balancing method to Round Robin for both.
Then create 2 virtual servers, one for HTTP on port 80 with an http profile applied and using the HTTP pool created above as the resource, and one for FTP on port 21 with an ftp profile applied and using the FTP pool created above.
You may need to add persistence and monitors to finalize the configuration, but that’s the basic setup.
HTH
/deb
