limiting TMSH iRules listing
Hi! I need to get a usable list of irules with their content for automation purposes. But what is getting into my way are built-in irules (those “_sys_” named with verified status).
Is there some way to list all the irules without the built-in ones? I’ve found out in tmsh documentation that you can use regexp in tmsh list ltm rule command, but how can I negate the search pattern. I tried some negative lookbehind but it doesn’t seem to work:
(tmos) list ltm rule @(\?
Any ideas?
You can try this: (tmos.ltm.rule) list [0-9a-zA-Z]*
