Issue with scan commend?
I am working on what should be a really simple irule, but for some reason I cannot get the scan command to work. I have simplified the entire rule down to the following code to trouble shoot.
set hh [string tolower [HTTP::host]]
log local0.info “$hh”
scan $hh %s.%s.%s.%s h1 h2 h3 h4
log local0.info “$h1 $h2 $h3 $h4”
The first log statement works and produces a log with something in the format of “sub.host.domain.suf” but I get an error when the second log fires.
TCL error: sample_scan - can’t read “h2”: no such variable while executing "log local0.info “$h1 $h2 $h3 $h4"”
I am just formatting the scan wrong?
Hi Steve, try this
when HTTP_REQUEST
set host [HTTP::host]
log local0. "host -> $host"
scan $host {%[^.].%[^.].%s} h1 h2 h3
log local0. "host -> $host ; h1 -> $h1 ; h2 -> $h2 ; h3 -> $h3"
Reference link:
http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/2346/iRules-101--16--Parsing-Strings-with-the-TCL-Scan-Command.aspx
Muhammad’s got it right, although you’d need one more iteration if you wanted 4 sections. The reason that your %s wasn’t working is that it is greedy and eats up everything until the next space, including the “.” characters.
From the reference:
s
The input field consists of all the characters up to the next white-space character; the characters are copied to the variable."
So in your case, to grab all four sections, you’d want something like:
scan $hh {%[^.].%[^.].%[^.].%[^.]}
tclsh testing:
% set hh sub.host.domain.suf
sub.host.domain.suf
% scan $hh {%[^.].%[^.].%[^.].%[^.]}
sub host domain suf
Keep in mind you could replace the last [^.] with a %s in case you end up with more than four chunks.
Colin
