Is there a way to check which member in the pool the load balancer has selected for a client to connect to in an irule? We are starting to enable SSL between the F5 and our servers, and would like to run the ssl enabled members with the non ssl members during the transition. So ideally, the irule would see the client being sent to server1/2/3 etc and set ssl:disable serverside, else ssl:enable serverside. Any help or other ideas I might not have thought of to do this would be appreciated.
Here’s a simple static example:
when LB_SELECTED {
if { [IP::addr [LB::server addr] equals 10.70.0.1] } {
SSL::disable serverside
You’ll need to apply a server SSL profile to the VIP and turn it off in the iRule if the selected server’s IP matches a non-SSL host. Also, depending on how many servers you have, it may also make sense to handle the SSL switching assignments in a data group.
ex.
10.70.0.1 := off
10.70.0.2 := on
10.70.0.3 := on
