Is AOM available in BigIP VE (Running in ESX)?
Hi there, I am setting up my first pair of virtual edition (VE) BigIPs currently and struggle to get AOM network access running.
When using physical BigIPs ESC-( does the trick, but when trying to enter this via the ESX console, as soon as I type ESC I get ^[ so I won’t be able to access the AOM menu.
Looking at K14594: Accessing the AOM Command Menu I am not seing VEs listed anywhere. So am I right that VEs generally do not offer any AOM at all and the idea is to do all the maintenance/troubleshooting via the ESX console?
If not - how do you configure network access to the AOM for VEs?
Cheers, Torsten
Hello, except error on my part AOM is available only on F5 hardware platform: The F5’s AOM (Always On Management) interface module is one of the fundamental administrative features offered by BIGIP appliances.
Hi, AOM is only available on Hardware platforms.
AOM is a dedicated system running on appliance not sharing the same CPU, RAM and disk.
In ESXi, you can do the same with:
  • Halt / restart system : VSphere client
  • remote access to console : VSphere client or Network virtual serial port.
