Hello All,
I need to perform SNAT in the current setup to route the return traffic via the F5.
I am looking for an Irule on a virtual server to use a different snatpool based on the actual client ip address and this has to scale up to 100 differnt clients using the same virtual server.
If client ip matches X -->Use SNATPOOL Y
X1 --> Use SNATPOOL Y1
X100 --> Use SNATPOOL Y100.
Raj
You have a few options, but the best two will to either use a switch statement, or use a data group.
By using the switch command, you can do something like:
switch [IP::client_addr] {
“1.1.1.1” { snatpool Y }
“2.2.2.2” { snatpool Y2 }
etc…
You can add a default statement at the end to catch anything that is not matched.
If you want to create a data group, you can create one with a type of string, with a name := value pair of client IP := snatpool name.
Then, an iRule with something like:
if { [set snatpoolname [class lookup [IP::client_addr] ] ne “” } {
snat $snatpoolname
Thanks for the suggestion …tested and the logic works .
Is there any limitation on adding number of entries in the data group ?
