We have a virtual server that has these three requirements:
- mTLS negotiation
- Match start of URI
- Match CN of certificate
Note: The the virtual server where this iRule is applied does not have a pool configured as I learned that the ‘reject’ command doesn’t necessarily do what I thought it did.
Testing has proven mTLS works and I think the CN validation does too. The problem is with URI matching. Using Postman, we’ve found that using a bogus URI fails indefinately until a valid URI is accessed by the same source. After that, the bogus URI works too. We just found this so haven’t done extensive testing.
Below is a simplified version of the iRule and this is the sequence of events:
https://virtualserver/bogus - fails
https://virtualserver/uri-a-yaddi-yaddi - works
https://virtualserver/bogus - This works for I don’t know why!!!
Note: Not sure the bogus URI has to be used first but that’s what the tester reported.
when CLIENTSSL_CLIENTCERT {
set subject_dn [X509::subject [SSL::cert 0]]
if { $subject_dn != "" }{
if { [HTTP::uri] starts_with "/uri-a" } {
if { $subject_dn contains "mauth-a" } {
pool serverpool-a-443
reject
} elseif { [HTTP::uri] starts_with "/uri-b" } {
if { $subject_dn contains "mauth-b" } {
pool serverpool-b-443
reject
The bogus URL does get rejected by the server but it should not have made it there to begin with. I’m no expert on iRules so I thought I’d post this before searching for a solution. If you happen to know what the problem is I’d be happy to save the time.
Also, I’m guessing there may be a better way to do this iRule but it was created by a consultant and thought to be working properly until today.
Thanks!
