Hello iRule Guru
currently i have an iRule that is doing two things, 1: if the http uri has /path1/example/ or /path2/example/ the traffic should go to pool-example
2: then if host equals api.example.com replace the header with host api.newexample.com .
the above conditions are working fine but we discovered that application needs one more condition, the additional condition would be if the uri has version2/sport1 and http method is POST, forward traffic to sport pool, can you please help me to write that condition.
if { [string tolower [HTTP::uri]] starts_with “/path1/example/” or [string tolower [HTTP::uri]] starts_with “/path2/example/”} {
pool pool-example
} elseif { [string tolower [HTTP::host]] equals “api.example.com ” } {
HTTP::header replace “Host” “api.newexample.com ”
pool api-newexample-com
You can try below code
if { [string tolower [HTTP::host]] equals "api.example.com" } {
HTTP::header replace "Host" "api.newexample.com"
return
switch -glob [string tolower [HTTP::uri]] {
"/path1/example*" -
"/path2/example*"
pool pool-example
"/version2/sport1*"
if { [HTTP::method] eq "POST"} {
pool sport_pool
reject
} default {
return
xuwen
August 27, 2021, 7:27am
3
pool pool-example
} elseif { ([HTTP::method] eq “POST”) and ([HTTP::uri] contains “version2/sport1”) } {
pool sport_pool
