Hi.
I added a irule with stream profile default on the virtual server, however, the application display 60f on the TOP the web browser, the configuration on the irule is:
if { [HTTP::path] eq “/” } {
HTTP::redirect “http://prueba.com.mx/prueba_prueba/prueba/prueba.jsp”
else {
STREAM::disable
when HTTP_RESPONSE {
if { [HTTP::header value Content-Type] contains “text”} {
STREAM::expression “@ServerIpAddress=10.10.5.2:8080@ServerIpAddress=prueba.com.mx@”
STREAM::enable
else {
STREAM::disable
you have idea of the problem, thanks for advanced
In order to help, more information is needed. What is the application, since “60f” is an application related error.
Overall, the iRule is straight-forward in functionality.
-I see that you are running Apache 2.4.39
Hi Shaun, the application is Tomcat, i find the problem, when configure a virtual server with a stream profile and http analytics profile, appear the string 60f on the top of web browser, you have idea why this happens?
Would you be able to post a screen capture as a reply, using the paperclip? --You can crop the area that shows the “60f”.
-Being that you are using Tomcat, the application seems to be more than just a 443 webpage, requiring a few more details to how the application works.
I’ve just ran into the same issue - disconnecting the web_analytics profile from the virtual server fixed it. Not quite sure yet what caused it, but here are some details of my system, in case it helps anyone else;
- Just upgraded to v15.1.0.2 (no issues with the same configuration under v14.1.2.1)
- VS has an HTTP profile, as well as SSL offloading, and an iRule and Local Traffic Policy
- Another VS with a standard pool and no funky iRules/LTP’s, but WITH web_analytics profile, did not show the same problem.
If I find out anything else, I’ll update this post.
Hi everyone, i opened support case and they told me to change the value of the variable avr.cspm.inject.location of “at_the_end” to “after_head”, i applied of command tmsh modify sys db avr.cspm.inject.location { value after_head } and its works
