irule to enable http/2 acceleration
Hello,
I got some case, we have some virtual server with irules we want to enable http/2 for specific FQDN, but we don’t want enable the http/2 profile on the virtual server, because it will impact all FQDN that handled by that virtual server.
it is possible to enable http/2 acceleration using irule? Or the only way to enable http/2 profile is using configuration utility only
I don’t believe this is possible because the profile use is done prior to the iRule being used to identify the specific HTTP header to select a different HTTP profile.
