iRule Remove char in a string
hello,
If I use this command:
set COUNTRY ([whereis [IP::client_addr] country]])
It gives me back a country in parentheses like (IT) …
How can i remove this parentheses ( and )?
I tried to use the string trim or map command, but did not succeded.
Any hint?
to remove parentheses from the result of:
remove it from the command:
set COUNTRY [whereis [IP::client_addr] country]]
