I’m hoping you guys can help me out. I have fumbled my way through this for weeks now. I’m trying to write an irule that routes to a different pool based on the value of a cookie.
#1 https://myapp.domain.com/alpha
#2 https://myapp.domain.com/alpha?arg=A
#3 https://myapp.domain.com/alpha?arg=B
The app by default should go to #1. I’m having to pass an argument in browser as workaround to test hitting against another pool. The app does several 302 redirects before the page loads, so I lose the (?agr= ) in uri after the initial execution. The first part works fine. It sends to the correct pool based on the arg set. It’s on the redirects that have the issue. Since the arg= is no longer set it falls into the last else. I’m checking for the cookie, but it is not there anymore and falls to the default.
set webUri [HTTP::uri]
set webHost [ string tolower [HTTP::host] ]
HTTP::header insert X-Forwarded-For [IP::remote_addr]
HTTP::header insert X-Forwarded-Host [HTTP::host]
if { ($webUri ends_with “arg=1”) } {
set orig_cookie [HTTP::cookie value “valueA”]
pool POOL1
return
elseif { ($webUri ends_with “arg=2”) } {
set orig_cookie [HTTP::cookie value “valueB”]
pool POOL2
return
else {
if { ( [HTTP::cookie exists cookie] ) } {
set new_cookie [HTTP::cookie value orig_cookie]
return
else {
set new_cookie [HTTP::cookie value null]
switch $new_cookie {
“valueA” {
pool POOL1
return}
“valueB” {
set tls no
pool POOL2
return}
default {
pool POOL3
return}
when HTTP_RESPONSE {
set node [IP::server_addr]:[TCP::server_port]
set nodeResp [HTTP::status]
# log connection info
log local0. [LB::server]
log local0. $node
log local0. $nodeResp
