Irule logic question
when HTTP_REQUEST { if { ([matchclass [string tolower [HTTP::uri]] contains Allowed_uri]) or ([matchclass [IP::client_addr] equals Allowed_IP]) } { } else {
log local0. “---CLIENT IP---[IP::client_addr] URI is [HTTP::uri]”
drop }
In the above irule, would the http request be permitted as long as either datagroup matches? It wouldn’t have to match both to be permitted because of the “or” logic?
Hi Lee,
I sometimes find it easier to read an iRule (especially when you include NOTs) by breaking the ‘or’ into separate ‘if’ conditions. Notice the “!” - this makes the condition a NOT.
So:
IF NOT datagroup URI, IF NOT datagoup IP, drop. (everything else will be allowed)
    if {(![class match [string tolower [HTTP::uri]] contains Allowed_uri])} {
        if {(![class match [IP::client_addr] equals Allowed_IP])} {
            drop
PS -
matchclass
has been depricated: DevCentral
Lee
Your iRule is almost correct but logic needs to be change from OR to AND:
    if {[matchclass [string tolower [HTTP::uri]] contains Allowed_uri] and [matchclass [IP::client_addr] equals Allowed_IP]} {
        return
        log local0. "---CLIENT IP---[IP::client_addr] URI is [HTTP::uri]"
        drop
reversing the logic, like MrPlastic has done, you can do the same with less using not and logic OR:
    if {(not [matchclass [string tolower [HTTP::uri]] contains Allowed_uri]) or (not [matchclass [IP::client_addr] equals Allowed_IP])} {
        drop
How would I rewrite my irule if I only wanted to permit URIs in Allowed_uri and just use the one datagroup and forget the source IP filter? Thanks for ur guys help.
This should be all you need, traffic not matching the URI data group will be dropped. Everything else will be permitted.
    if {(not [class match [string tolower [HTTP::uri]] contains Allowed_uri])} {
        drop
