Irule latency
Hi
I developed irule to inspect session id and perform persistence but calculating time it might take up to 30 seconds to do this, Is there anyway to reduce the time and how can i know reason of this delay because its not related to the box itself
    if { ( [HTTP::method] eq "POST") and
         ( [HTTP::path] equals "/url") } then {
        if { [HTTP::header value "Content-Length"] < 5000 } then {
            HTTP::collect 3000
            HTTP::collect 5000
    HTTP::header remove "Accept-Encoding"
when HTTP_REQUEST_DATA {
    set session [findstr [HTTP::payload] ":sessionID>" 8 "<"]
    if { $session ne "" } {
        persist uie "$session" 1200
when HTTP_RESPONSE {
            HTTP::collect 5000
when HTTP_RESPONSE_DATA {
    set session [findstr [HTTP::payload] "" 8 "<"]
    if { $session != "" } {
        persist add uie $session 1200
I think you need to drop the quotes under HTTP_REQUEST_DATA:
Within the HTTP_REQUEST_DATA, use the if-conditions to function only for specific conditions and not for all.
Can you reduce the HTTP::collect data following the example provided here.
You can probably drop the HTTP_RESPONSE & HTTP_RESPONSE_DATA events. Use the remaining iRule and add it to a UIE persistence profile as an iRule and see if it will work.
I haven’t run into latency issues with persistence based on POST data and this could help you, if you are looking for a sample iRule.
I think the problem is you collect 3000 bytes even if the content length is less than 3000.
try this irule:
   Trigger collection for up to 1MB of data
  if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576}{
    set resp_content_length [HTTP::header "Content-Length"]
      set resp_content_length 1048576
   Check if $content_length is not set to 0
  if { ([HTTP::status] == 200) && ($resp_content_length > 0)} {
    HTTP::collect $resp_content_length
     do stuff with the payload
    find the application unique identifier between  and  (11 is the length of  string)
    persist add uie [string trim [findstr [HTTP::payload] "" 11 ""]]
    set req_content_length [HTTP::header "Content-Length"]
      set req_content_length 1048576
  if { ($req_content_length > 0)} {
    HTTP::collect $req_content_length
    persist uie [string trim [findstr [HTTP::payload] "" 11 ""]]
the
string trim
command remove space and new lines characters that can be added in XML format.
