Folks
I have requirement to the request start with /abc/ directory and contains the parameter si or di the value of this parameter should not exceed more than 50 characters , if exceed should drop if less should allow. cheers snl
Folks
done some research found below , how i can call the parameters in this particular those 2 value
when RULE_INIT {
set DEBUG 1
set sec_http_max_post_data_length 50
if { [string tolower [HTTP::uri]] equals "/abc/" and [HTTP::method] equals "POST" } {
set len [HTTP::header "Content-Length"]
if { [expr $len > $::sec_http_max_post_data_length] } {
log local0. " SEC-ALERT: POST Length: uri=[HTTP::uri]; len=$len; max_len=$::sec_http_max_post_data_length"
reject
You’ll want to create static variables in RULE_INIT to maintain CMP.
when RULE_INIT {
set static::DEBUG 1
set static::sec_http_max_post_data_length 50
if { ( [string tolower [HTTP::uri]] equals "/abc/" ) and ( [HTTP::method] equals "POST" ) } {
if { [expr {$len > $static::sec_http_max_post_data_length}] } {
log local0. " SEC-ALERT: POST Length: uri=[HTTP::uri]; len=$len; max_len=$static::sec_http_max_post_data_length"
reject
