Hello,
I’m attempting to insert a header which contains error values from a ‘Sideband’ response.
I can’t post the whole code due to what it does.
For example:-
set host_header [HTTP::host]
set host_status [string tolower [class match -value [HTTP::host] starts_with DataGroup1]]
set uri [HTTP::uri]
set uri_status [string tolower [class match -value [HTTP::uri] starts_with DataGroup2]]
set sessionid ""
if {[HTTP::cookie exists "JSESSIONID"]} {
set sessionid [HTTP::cookie value "JSESSIONID"]
if {[HTTP::method] eq "POST" && $host_status eq "on" && $uri_status eq "on"}{
if {[HTTP::header exists "Content-Length"] }{
set content_length [HTTP::header "Content-Length"]
set content_length 1048576
HTTP::collect $content_length
when HTTP_REQUEST_DATA {
set payload [HTTP::payload]
#DO SOME STUFF#
set pool1 [class match -value locale starts_with Datagroup3]
if { [active_members $pool1] < 1 } {
log local0. "The pool member is down"
HTTP::header insert x-error-code Ts-Unavailable
***Above not inserting Header***
#CONSTRUCT SOAP PAYLOAD#
#POST DATA TO SIDEBAND SERVICE#
set conn [connect -timeout 1000 -status conn_status %Virtual1]
set conn_info [connect info -idle -status $conn]
set send_info [send -timeout 1000 $conn $request_to_send]
set recv_request [recv -timeout 1000 $conn]
close $conn
if {$recv_request contains "<errorCode>"}{
set start_error "<errorCode>"
set end_error "</errorCode>"
set pos_error [ string first $start_error $recv_request]
set error_path_and_value [substr $recv_request $pos_error "</errorCode>"]
set error_value [getfield $error_path_and_value ">" 2]
HTTP::header insert x-error-code $error_value
#STRIP OUT DATA#
#The Service replied with a valid response.
#REPLACE DATA WITH RECEIVED DATA#
HTTP::release
Should this insert the Header into the HTTP Request destined for the Default Virtual/Pool? Am I missing something?
Thanks,
