irule for URI
URL : www.test.com/abc/test/login
I need to match the condition as below
If my host = test.com & uri starts with /abc
then the below url only should work
"www.test.com/abc/test/login "
else page not found.
Note: This should not affect rest or the URI in the host.
Can any one provide the iRule for implementing this.
Maybe something like this?
     Check host is www.test.com
    if {[string tolower [HTTP::host]] eq "www.test.com"}{
        Check if URI starts with /abc
       if {[HTTP::uri] starts_with "/abc"}{
           Check if URI is not exactly "/abc/test/login"
          if {[HTTP::uri] ne  "/abc/test/login"}{
              Send a 404 response
             HTTP::respond 404 content {not found}
Aaron
