iRule for pool selection based on HTTP::URI
Hello
We have 2 pools with different sets of application servers. Pool_1 contains few WebLogic servers and Pool_2 contains few Tomcat servers. We want to redirect clients to specific pool based on URI. We are trying to use the following iRule but it seems when a specific URI is matched the URL is being redirected to HTTP instead of HTTPS. The default pool is always being redirected to HTTPS as expected. Below is the iRule.
when CLIENT_ACCEPTED {
set DEFAULT_POOL [LB::server pool]
if { [HTTP::uri] starts_with "/states" } {
pool states
pool $DEFAULT_POOL
How is your “states” pool set up? Is it configured to use port 80 instead of 443? If so, that is probably your issue. There is nothing in this iRule that is doing a HTTP redirect.
My default VS is “prod_vs” on 443 and default pool is “prod_pool” with 4 members (app{1-4}:7001). I’m doing SSL offloading on LTM. This has been working for me for years. Now I got a new requirements where I had to create a new pool “states_pool” and assign 2 members (app{4,5}:8080) under this pool. My goal is to if clients hit @ https://secure.mydomain.com then LTM would forward the request to “prod_pool” and if clients hit https://secure.mydomain.com/states/ then LTM would forward the request to “states_pool”. Which is why I was trying to use the iRule.
With the iRule when I hit https://secure.mydomain.com it’s working as expected but when I hit https://secure.mydomain.com/states/ it’s being redirected to http://secure.mydomain.com.
states_pool isn’t assigned to any VS.
I added some logs and hit both URL and here is the log.
May 4 13:00:03 ltm01-sj info tmm[11190]: Rule /Common/_forward_states : Selecting default pool as first condition failed. May 4 13:00:23 ltm01-sj info tmm[11190]: Rule /Common/_forward_states : URI matched. Selecting states pool.
Do you see the browser address bar change to http://secure.mydomain.com? If so, someone is sending an HTTP redirect, but it is not this iRule. The web servers could be doing it, or do you have an http class or something configured on this virtual server?
Redirecting to the states pool via this iRule would be transparent to the user.
Hi
Turned out there isn’t an easy way to configure SSL offloading for Tomcat or at least I don’t know any. So I updated the iRule as follows.
  if { [HTTP::uri] starts_with "/foo" } {
     pool foo
     pool bar
when HTTP_RESPONSE {
   if { [HTTP::status] contains "302" && [HTTP::header Location] contains "http://" && [HTTP::header Location] contains "/foo" }{
      HTTP::header replace Location [string map -nocase {"http://" "https://"} [HTTP::header Location]]
