iRule for Find&Replace
Hi everyone,
i need to implement an irule for find a string into the HTTP Body and replace with another.
I tried to search a function to satisfies my request but i found nothing.
I tried with the String functions but i fail to replace all substring into the HTTP Body.
Can you help me please?
Thanks for any answer.
Regards,
Fabio
have you looked at the stream profile?
As Jason suggests, you can take a look at the STREAM::expression wiki page for examples of rewriting response content. You’ll need to either disable compression on the pool members or by removing the accept-encoding request header.
http://devcentral.f5.com/wiki/default.aspx/iRules/stream__expression
    Remove Accept-Encoding header to prevent server response content compression
   HTTP::header remove Accept-Encoding
Aaron
