iRule for Dynamic NATING
Hi All,
Is anyone had done some dynamic NATing for example,
Origin:
10.19.0.0/19
Translation:
172.26.0.2 -172.26.31.254
Thanks!
Ferdz
You should be able to use an SNAT Pool for this. Can you tell us a bit more about the exact requirements and your planned design?
Hi Steve,
The reason why we need to NAT IP addresses because of the conflicting IPs, we are currently replacing a Cisco router using an F5.
Here some snapshots from NAT Router:
ip nat pool SUN1 172.26.0.2 172.26.31.254 netmask 255.255.224.0
ip nat inside source list 11 pool SUN1
access-list 11 permit 10.19.0.0 0.0.31.255
ip nat inside source static 10.157.8.84 172.26.210.84
ip nat outside source static 10.103.33.11 10.171.14.111
Here’s the flow
Company A <> Router Company A <> F5 <> Router Compny B <> Company B
Thanks!
Ferdz
Hi Steve,
Here’s the flow
Thanks!
Ferdz
Hi Steve,
Here’s the flow
Thanks!
Ferdz
Hi Steve,
Here’s the flow
Thanks!
Ferdz
Hi Steve,
Here’s the flow
Thanks!
Ferdz
Thanks. I’ll reply in your other post here: https://devcentral.f5.com/community…852/asg/39
