iRule - Fallback Persistence
Hi - I’m trying to create an iRule for the Persistence Profile of one of my applications. The preferred method is to use cookie - the application actually injects a cookie in the HTTP RESPONSE and the F5 looks for this cookie in both the HTTP RESPONSE and HTTP REQUEST to do persistence, identical to how JSESSIONID works.
However in the event that the client has configured their browser to reject / disable cookies, the expectation is that we persist based on their source IP, however as they come in to our data centre via Akamai, we actually need to extract their IP from the X-Forwarded-For header.
What I came up for this was:
    if { [HTTP::cookie exists "App_SessionId"] } {
        persist uie [HTTP::cookie "App_SessionId"] 1800
    else if {[HTTP::header X-Forwarded-For] != ""} {
        persist uie [lindex [ split [lindex [HTTP::header values X-Forwarded-For] 0] "," ] 0] 1800
    else {
        persist uie [IP::client_addr] 1800
when HTTP_RESPONSE {
        persist add uie [HTTP::cookie "App_SessionId"] 1800
I haven’t had the chance to test this but reviewing the logic I see that we may have a problem with the first request cominf from the user’s browser.
When a user first lands on the website, the
HTTP_REQUEST
from their browser will not have the
App_SessionId
cookie and this causes the LTM to add a persistence record based on the
X-Forwarded-For
header, or add a persistence record based on the user’s source IP address.
When the request makes it to the server and the server responds (
HTTP_RESPONSE
), that response will have a
App_SessionId
cookie, and the LTM adds another persistence record based on this cookie.
Then the subsequent
HTTP_REQUEST
from the users browser will have the
App_SessionId
cookie, and this will now match the
section of the iRule and they will be persisted to the same server that inserted the cookie.
This is good but there’s the loose end which is the initial persistence record based on the
X-Forwarded-For
header that’s lingering.
  1. Would this lingering persistence record based on the
    X-Forwarded-For
    header cause a conflict with the persistence record based on the
    App_SessionId
    cookie?
  2. How do I clean up this loose end?
On the flip side, if the user had configured their browser to reject cookies, the persistence record based on the
X-Forwarded-For
header is vital to maintain session consistency. But now we have the loose end of the
persist add uie [HTTP::cookie "App_SessionId"] 3600
in the
HTTP_RESPONSE
